Axminster Professional 100mm Steel Split Ring
- Designed for use with our 100mm galvanised ducting
- Install or extend ducting anywhere in your workshop
- Use alone or connect to a wall bracket
- Best quality galvanised steel
- Easy fit for fast fixing and installation
These Split Rings are designed for use with our 100mm galvanised ducting.They are designed for fast and neat installation of 100mm ducting runs along walls or across ceilings. The two part, bolt together design makes fixing simple and easy. Each Split Ring has a countersunk hole on one half to allow it to be screwed directly to the wall or ceiling or used with a wall bracket. Use these Split Rings to install or extend ducting anywhere in your workshop. Produced from best quality galvanised steel.
Ducting Size | 100 mm |
EAN Barcode | 5052511130764 |
Model | KVDA |
- Standard Delivery* - £1.99
