Axminster Professional 100mm Sliding Blast Gate
109342
From £48.48 £40.40
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Friday 11th Jul
  • Simple and effective shut-off valves
  • For use with 100mm galvanised ducting system
  • Isolate those machines not in use
  • Designed to prevent becoming clogged or jammed
  • Very robust can be fixed in horizontal or vertical
  1. Axminster Professional 100mm Sliding Blast Gate
Total:
£292.62 £243.85
These Blast Gates are designed for use with our 100mm galvanised ducting. They are very robust and manufactured using only the highest quality galvanised steel. They can be fixed in horizontal or vertical runs of ducting. The Gates feature a clever and simple design, when you open the gate, any dust that may have been trapped between the blade and the body is released, thus preventing any problem with the blade sticking.
Blast Gates are simple and effective shut-off valves and an essential part of any dust extraction system. Generally a gate is placed in the run of ducting to each machine connected to the system. By closing the Gates you can isolate those machines not in use and get the full benefit of your extraction on the machine in use.
