Earn extra with DOUBLE Points on all purchases!
Hose Cuff - 100mm
Hose Cuff - 100mm
- Easily fitted flexible rubber hose cuff
- 100mm long
- Moulded RH thread screws directly onto Axminster's 100mm clear hose
- Snug fit onto a 100-110mm diameter machine extraction port
This is an easily fitted flexible rubber machine cuff for attaching hose to machinery. One end has a moulded RH thread that screws directly onto our 100mm clear hose, the other end of the cuff is a snug fit onto a 100-110mm diameter machine extraction port. Turn the cuff inside out if it does not match your hose spiral. It makes for an easy connection, and re-connecting the extractor from one to machine to another as simple as possible. NOTE, this cuff fits all current Axminster clockwise spiral 100mm clear hoses directly.
EAN Barcode | 5052511110230 |
- Standard Delivery* - £1.99
