Easy Wood Tools Hollowing System
Hollowing Made as Easy as 1-2-3 With Easy Wood Tools
Hollowing woodturning projects, such as boxes, vases and hollow forms, can be challenging, especially when working deep inside a piece with limited visibility.
Easy Wood Tools simplifies the process with their 1–2–3 hollowing system. Each carbide hollower is designed for a specific stage, helping you work safely, accurately and with greater control from the rim to the deepest part of the form.
How the 1–2–3 Hollowing System Works
Each tool has a defined role:
- Hollower #1 – Bulk removal
- Hollower #2 – Shaping and refining
- Hollower #3 – Finishing and deep hollowing
Used in sequence, they create a simple, repeatable workflow for hollowing any form.
Hollower #1 – Fast Material Removal
Designed to open up the form and remove the majority of internal waste.
- Clears material quickly
- Establishes the cavity shape
- Ideal for working just below the rim
Best for: starting hollow forms and roughing interiors
Hollower #2 – Shaping and Control
Refines the internal shape and improves reach into the workpiece.
- Smooths curves and transitions
- Develops a consistent internal profile
- Adds control mid-process
Best for: shaping and refining interiors
Hollower #3 – Deep Reach and Finishing
Built for precision work deeper inside the form.
- Reaches into narrow cavities
- Enables light finishing cuts
- Helps achieve even wall thickness
Best for: final finishing and deep hollowing
Choosing the Right Size: Mini, Mid-Size or Pro
Easy Wood Hollowers are available in Mini, Mid-Size and Pro across all three stages (#1, #2 and #3):
Mini Hollowers
– ideal for smaller lathes, boxes and compact hollow forms
Mid-Size Hollowers
– a versatile, all-round choice for most projects
Pro Hollowers
– designed for larger hollow forms, offering greater reach and stability
The cutting action stays the same; size simply affects scale, reach and control.
Hollowing Sets: A Complete Solution
Easy Wood Hollowing sets combine Hollower #1, #2 and #3 into one package, giving you a complete system from the outset.
A great option if you want a ready-made workflow, from opening up to final finishing.
Why Use Easy Wood Hollowing Tools?
- Carbide cutters – no sharpening required
- Simple, flat tool presentation
- Reduced risk of catches
- Greater confidence when hollowing inside forms
A Simpler Way to Hollow
By working through the stages, remove-shape-finish, the Easy Wood Tools system removes much of the complexity from hollowing.
Whether you’re creating small boxes or larger hollow forms, the 1–2–3 approach makes it easier to achieve consistent results with confidence.
With the right tool at each stage, hollowing really can be as easy as 1–2–3.
Easy Wood Tools Mini EASY HOLLOWER™ #1
Easy Wood Tools Mini EASY HOLLOWER™ #2
Easy Wood Tools Mini EASY HOLLOWER™ #3
Easy Wood Tools Mid-Size EASY HOLLOWER™ #1
Easy Wood Tools Mid-Size EASY HOLLOWER™ #2
Easy Wood Tools Mid-Size EASY HOLLOWER™ #3
Easy Wood Tools Pro EASY HOLLOWER™ #1
Easy Wood Tools Pro EASY HOLLOWER™ #2
Easy Wood Tools Pro EASY HOLLOWER™ #3
Easy Wood Tools Mini Easy Hollowing™ Set 3-Piece
Easy Wood Tools Mid-Size Easy Hollowing™ Set 3-Piece
