Bosch HM-RIFF Segmented Saw Blades (Starlock)
- Tungsten carbide abrasive cutting edge
- 85mm 2.5mm cutting thickness, 30 grit abrasive
- Suitable for cleaning narrow seams such as grout removal
- Great for cutting fibreglass, epoxy and similar materials
- Fits Bosch, Makita, Fein and other similar Multi-Tools
- Starlock fitting for maximum power transfer
Bosch BiM Plunge Cut Blades (Starlock)From £7.88 £6.57
Bosch BiM C-Tec Japanese Style Plunge Cut Blade (Starlock) 65mmFrom £16.78 £13.98
These blades have a host of uses, excellent for cleaning grout in narrow seams between small and large tiles with no damage to adjoining tiles, as well as easy and precise cutting in fibreglass and epoxy parts. The edge is coated in a tungsten carbide abrasive for long life.
Blade diameter 85mm, 2.5mm kerf, 30 grit.
Suitable for Bosch, Makita and Fein (10mm) Multi-Tools and others using the Oscillating Interface System (OISâ„¢) or Starlock fitting which ensures a secure fit with maximum power transfer.
EAN Barcode | 3165140492454 |
Model | ACZ65RT HM / ACZ85RT |
- Standard Delivery* - £1.99
