Bosch Impact Control Screwdriver Bits PZ2 25mm (8)
- 8 x 25mm long, Pozidriv Pz2 impact 1/4" hex bits
- Specially heat treated torson zone, 10 x life of standard impact bits
- Supplied in a Pick and Clic holder
This set of eight bits comes in a Bosch Pick and Click system holder, which keeps the bits secure when not in use. The holder can be used alone or easily clicked into the Bosch Pick and Click Cases M or L for replacement or replenishment. This set comprises eight, 25mm long bits with 1/4" hex shanks and pozidriv Pz2 tips; these are by far the most commonly used bits.
These Bosch Impact Control bits are as tough as it gets. The bits are fully impact rated and suitable for use in high torque impact drivers. They will last up to ten-times the longer than standard impact bits. The bits are S2 Modified Steel with an extended torsion zone, which absorbs peaks in torque, greatly reducing breakage.
Bit Length | 25 mm |
Bit Size | Pz2 |
Bit Type | Pozi |
EAN Barcode | 3165140851152 |
Model | Impact Control |
- Standard Delivery* - £1.99
