Bosch Impact Control Screwdriver Bits T25 25mm (25)
- 25 super tough Torx T20 impact rated bits
- 10 times life of standard impact bits
- Suitable for use in high torque impact drivers
- Specially heat treated torson zone
- 25mm, 1/4" hex bits for all screw driving needs
Bosch SELFCUT 6 Piece Speed Flat Bits Set (Hex Shank)Special Price £25.00 £20.83 was £32.58 £27.15 Save £7.58 £6.32
These Bosch Impact Control bits are as tough as it gets. The bits are fully impact rated and suitable for use in high torque impact drivers. They will last up to ten-times the longer than standard impact bits. The bits are S2 Modified Steel with an extended torsion zone, which absorbs peaks in torque, greatly reducing breakage.
There are twenty-five Torx T25 bits 25mm long with 1/4" hex shanks supplied in a handy tic tac box for storage and quick identification. The box keeps the bits secure when not in use.
Bit Length | 25 mm |
Bit Size | T25 |
Bit Type | Torx |
EAN Barcode | 3165140980258 |
Model | Impact Control T25 |
- Standard Delivery* - £1.99
