Button Fix Marker Tool Type 2
106318
- Accurate marking for Button Fix Type 2
- Leaves indents showing exact positioning
- Reusable for next panel, pack contains 4 marker tools
Customers Also Bought
These marker tools make a handy accessory helping you to mark out where to install a Type 2 Button Fix. The marker tool helps in the initial placement of the button. After fixing the button in place, hold the panel in its intended position. A firm tap on the panel will leave indents on the rear of the panel, indicating the exact positioning for the Type 2 Button Fix. Remove the markers, which can be reused when marking out the next panel. Each pack contains 4 marker tools.
