UJK Parf System Reamer for 20mm Holes
- Restores the accuracy of 20mm bench dog holes
- Removes stray wood fibres that affect the fit of bench dogs
- Reams bench dog holes distorted due to changes in humidity
The beauty of the UJK Parf system lies in its accuracy, in particular the close fit of bench dogs and accessories in the 20mm dog holes. Depending on the material chosen for the bench top, sometimes a stray wood whisker or change in humidity can affect the fit.
The UJK Reamer is designed to remedy the problem and restore the quality of 20mm holes. The Reamer removes stray wood fibres that hinder the insertion of UJK bench dogs and UJK Parf Guide System accessories. The Reamer improves the quality of holes in bench tops. The UJK Parf System Reamer is made from stainless steel for use in a power drill.
NB: For use with portable drills only.
| EAN Barcode | 5052511124367 |
- Standard Delivery* - £5
