Bottle Opener Kit - Chrome
- Good quality bottle opener kit
- Would make a nice gift
- Add your own timber or acrylic handle
This is a good solid bottle opener kit with a chrome finish. Just add a handle using timber or acrylic for your own unique designs. We would recommend using epoxy resin adhesive to attach the opener to your turned or carved handle. With the interest of our customers in mind, we have tested this product extensively.
The spigot has a 3/8" x 16tpi thread by 30mm long, making it possible to drill and tap the blank using a 3/8" UNC tap, if you so wish. In all other cases you will have to judge the diameter of the pilot hole. If your blank material is hard, a small pilot hole risks cracking. We recommend using CA or epoxy glue for extra security.
Difficulty | Beginner |
EAN Barcode | 5052511060696 |
Pilot Diameter | 8.5 mm to 9.5mm (depending on material density) |
Thread | 3/8" x 16tpi |
Thread Length | 30 mm |
- Standard Delivery* - £1.99
