Diamond coated blade for high performance and longer service life
Ø 75mm diameter x 2.2mm cutting width
Segmented, ideal for working in corners and on edges without overcutting
Ideal for small repair work, cutting marble, concrete, grout joints, cutting out marble, very hard epoxy resin and cement joints
Compatible with all Oscillating Multi-Tools using the OIS fitting system; FEIN MultiMaster, FEIN MultiTalent, Bosch GOP, Bosch PMF, AEG, Hitachi, Einhell, Makita, Metabo, Milwaukee, Ryobi, Skil, Dremel and others. DeWALT Oscillating Multi-Tools will require an adapter
For small scale repair work on tiled surfaces, grout removal and cutting grooves in plaster, brick or aerated concrete, this diamond coated blade delivers high performance and longer service life. Blade is Ø 75mm diameter, cutting width 2.2mm. FEIN 114 blade.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the tip of the blade. No more wasted power, means faster working, minimised vibration, the potential for longer blades and better results. Starlock accessories are compatible with all OIS and OIS-compatible power tools currently on the market. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
