Festool FSV/2 Guide Rail Connectors (Pkt 2)
- Connect 2 Festool guide rails as if they were a single piece
- Self-aligning, quick and convenient to use.
- Two rails became one; straight, true and stable
Festool TCT Saw Blade Thin Kerf Fine - 160mm x 1.8mm x 20mm 42TFrom £58.68 £48.90
Festool TCT Saw Blade Thin Kerf Laminate - 160mm x 1.8mm x 20mm 52TFrom £88.78 £73.98
The FSV/2 connects two guide rails as if they were made from a single piece. They ensure precise cuts over the entire length of two or more connected guide rails. The two connecting pieces allow you to join two guide rails ensuring the result is straight, true and stable. The self-aligning function makes them quick and convenient to use. The connecting pieces are compatible with all Festool guide rails. The laser engraving ensures that the two connecting pieces are used in the correct order.
EAN Barcode | 4014549391723 |
Manufacturer Part Number | 577039 |
Model | FSV/2 |
- Standard Delivery* - Free
