Heavy duty routing with exceptional precision
Designed for professional joiners, cabinet makers and serious woodworkers, the Festool OF 2200 EB-Plus Router delivers the power, control and confidence needed for precise routing work.
Applications
Routing, rabbeting, grooving, profiling and creating worktop corner joints are all made easy with the OF 2200 EB router.
Powerful and accurate
The OF 2200 EB set boasts a 2200 watt motor system, with powerful low-speed torque and variable speed allowing the highest levels of precision.
Clean
A chip deflector ensures all excess materials are safely caught. Thanks to its 360⁰ rotation, it can also be used on curved edges.
Safe
Risk of injury is minimised thanks to the built-in fast acting break system. Ergonomic handles ensure easy manoeuvrability.
Convenient
FastFix feature is included, permitting the efficient change of base runners and copying rings, whilst the ratchet principle ensures the easy exchange of router bits.
Precision
Routing depth accurate to 1/10 mm thanks to the clearance-free depth setting with zero function. The soft-grip and drag indicator are arranged ergonomically.
Optional Accessory Set
Increase the capability of your router further with this set, all supplied in a SYS M 237 SYSTAINER: 4 baseplates, parallel side fence with fine adjustment, extraction hood, 2 guide rods, 17mm, 24mm, 27mm and 40mm guide bushes and guide rail adaptor. Find out more...
