Festool SYMC 70 EB Basic Compound Mitre Saw 18V (Body Only)
- Cuts along the dissecting angle at the same time
- Back fence moves in synchronicity to create interior and exterior angle cuts
- Trolley system allows portability
- Body only
- Part of the 18V range
- Runs on 2 x 18V batteries (sold separately)
- No wires, no trip hazards
- Variable speed
- LED spotlight for clear, guided cuts
- Mitre saw is the same height as the systainer (sold separately) which adds a portable workbench
- Dust collection bag to collect chips without an extractor (sold separately)
- Show More
The SYMC70 is an innovative mitre saw for your woodworking workshop. Designed for the woodworker who creates highly accurate cuts for architrave, coving, trim etc, and need a versatile, precise and agile mitre saw.
One corner, one setting: the back fences move in synchronicity to set the saw for interior and exterior angles in just one setting, cutting the dissecting angle perfectly each time. The machine has a cutting width of up to 80mm, the maximum cutting height of the interior cutting angle is 64mm, which can be adjusted to 0-68°, and the exterior height angle of up to 70mm, which can be adjusted to 0-60°, setup is very quick and simple.
With the SYMC70 you can saw strips twice as fast than a regular compound saw, without making calculations, but keeping the accuracy.
The SYMC70 runs on two 18V batteries (not supplied) with a brushless EC-TEC motor with variable speed, for sufficient power and a long run time. Grounded onto a smooth trolley system, making this mitre saw as portable as you are. Perfect for working on site or in a smaller workshop, with no trip hazards, optimising your workspace where it suits you. The trolley can be cleverly heightened to the same level as the Festool SYS3M137 systainer, giving you an additional portable workbench for longer pieces.
The SYCM70 is packed with details to simplify your workspace; An LED spotlight projects the saw blades shadow on to the workpiece, giving you clear guided cuts every time. For reduced dust, an optional chip collection bag (Festool No. 577173) collects dust without a mobile dust extractor.
The SYMC70 is a versatile piece of kit, worthy of space in any workshop, but especially those who are working in kitchen projects, floor laying, or with projects with interchangeable cuts.
Please Note; this is a body only machine supplied without batteries or charger.
Part of the Festool 18V family.
Supplied with: circular saw blade WOOD FINE CUT HW 216 x 2, 3 x 30 W48, precision adjustable square, roller set, workpiece clamp, hex key WAF 6, hex key WAF 2.
