Festool TCT Saw Blade Fine - 216mm x 2.3mm x 30mm 60T
- 60 teeth, 216mm diameter, 30mm bore
- For clean, splinter-free crosscuts
- Designed for cutting solid wood and coated or veneered panels
- Generous carbide tips ensuring a long working life
Trend Tool and Bit Cleaner - 532mlSpecial Price £14.78 £12.32 was £16.78 £13.98 Save £2.00 £1.67
Festool TCT Saw Blade Universal - 216mm x 2.3mm x 30mm 36TFrom £65.28 £54.40
Festool TCT Saw Blade Aluminium/Plastic - 216mm x 2.3mm x 30mm 64TFrom £116.48 £97.07
The Festool TCT (Tungsten Carbide Tipped) circular saw blades offer a perfect combination of cutting performance and quality results. Manufactured in accordance with Festool’s uncompromising standards, they have generous carbide tips ensuring a long working life. These 216mm blades fit the Festool KS60 compound sliding mitre saw, but can of course fit any saw able to take this size. The W60 features 60 teeth, designed for clean, splinter-free crosscuts in solid wood as well as coated or veneered panels.
Blade Diameter | 216 mm |
Bore Size | 30 mm |
EAN Barcode | 4014549212240 |
Hook Angle | 5° Negative Rake |
Kerf | 2.3 mm |
Maximum RPM | 5,000 rpm |
Model | W60 |
Plate Thickness | 1.6 mm |
Teeth | 60 |
Tooth Format | ATB |
- Standard Delivery* - Free
