freud LU1C Saw Blade - 400mm x 4mm x 30mm 34T
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
Please check Click & Collect in-store stock for availability.
- Hi-Density Industrial Carbide teeth for long life
- Fast efficient rip cuts in soft and hard solid wood
- Alternate Top Bevel teeth with positive hook angle
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)Special Price ÂŁ24.98 ÂŁ20.82 was ÂŁ29.98 ÂŁ24.98 Save ÂŁ5.00 ÂŁ4.17
Axminster Professional Stainless Steel Metric Rule - 300mmSpecial Price ÂŁ2.68 ÂŁ2.23 was ÂŁ3.58 ÂŁ2.98 Save ÂŁ0.90 ÂŁ0.75
Freud’s industrial circular saw blades are designed for cutting solid wood, wooden panels and manmade boards. The blades are designed to deliver; high performance, a quality finish and longevity.
The superior performance of these saw blades comes from several unique features. Silver I.C.E, is a specifically engineered coating that is heat resistant and protects against resin build-up and corrosion. Anti-vibration slots offer a flawless finish, stabilising the blade and reducing chatter. Expansion slots dissipate blade stress and reduce noise. Each blade type within the range uses a specific grade of freud’s own Hi-Density Carbide; matched to the blades intended use. This carbide enables the carbide teeth on Freud's blades to last up to four times longer than standard products.
These blades deliver outstanding finishing even under extreme working conditions.
Blade Diameter | 400 mm |
Bore Size | 30 mm |
EAN Barcode | 8025331499509 |
Hook Angle | 10° |
Kerf | 4.0 mm |
Maximum RPM | 3,100 rpm |
Model | F03FS04609 |
Plate Thickness | 2.8 mm |
Teeth | 34 |
Tooth Format | ATB |
