Z-Saw Blade for Japanese Dozuki-Me Tenon Saw - Hardwood 240mm
- Specially designed blade for cutting hardwood
- Robust teeth with fine 21tpi teeth
- Cross, rip and mitre cuts with equal precision
This specially designed dozuki saw blade easily clips into the handle of our Dozuki-Me Saw. It has sturdy teeth and a fine 21tpi pitch. These robust and sharp teeth are perfect for cutting precise joints in hardwoods. The special tooth grind enables cross, rip and mitre cuts with equal precision.
Blade Thickness | 0.30 mm |
EAN Barcode | 4963041071247 |
Length of Blade | 240 mm |
Saw Blade Type | Crosscut |
Tooth Pitch \ tpi | 1.21 mm \ 21 tpi |
- Standard Delivery* - £1.99
