Makita DTM52Z Brushless Cordless Multi-Tool 18V (Body Only)
- Sawing, sanding, polishing, scraping, the DMT52Z gets it done
- Fully compatible with all Starlock accessories
- Comfortable with slim grip and exceptionally low vibration
The Makita DTM52Z is fully compatible with Starlock, Starlock Plus and Starlock Max accessories. The wide range of available accessories makes the DTM52Z a real problem solver for many professional trades. Saw, sand, scrape, polish and more.
This body only cordless multi tool has a maintenance free brushless motor, which delivers the power efficiently and effectively giving you long battery run times. The DMT52Z features a soft start, variable speed control and constant speed under load. It is a well balanced machine with a slim grip for better control and comfort. The AVT, anti-vibration technology, significantly reduces vibration. The AVT adds to the comfort and minimises hand fatigue, even when using the machine for an extended period. A bright LED work light illuminates the working area. Changing accessories is completely tool-less and offers 12 angle settings for the best approach to the job.
This is a body only machine without battery or charger.
