Mirka DEROS II 350CV 77mm Orbit Sander With Deco Solution Kit
111680
From £492.98 £410.82
1 Review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Friday 18th Jul
  • Compact, highly manoeuvrable, perfect for small jobs
  • Upgraded 300W brushless motor for high performance
  • LED speed indicators to easily adjust variable sanding speed
  • 5mm orbit for fast material removal
  • 77mm pad for greater access to tight spots
  • Low profile with low weight, use in any position
  • Soft start and electronic brake for controlled sanding
  • Bluetooth technology for monitoring vibration levels
  • Kit includes 150 Abranet Ace discs
The Deros II 350V is unique; with a compact body, 77mm disc and low weight (only 0.8kg), it is the perfect small sander. In the Deros II 350CV, you have a low profile, easily manoeuvrable sander, with efficient extraction and minimal vibration and sound levels. This 77mm sander with its user-friendly, compact body reaches small areas a regular sander cannot reach. The design makes it perfect for tackling small repairs, hard-to-reach areas, furniture restoration, painting prep, auto body dent, scratch repair and more. No more tired arms and wrists caused by holding a heavy awkward sander when sanding tricky areas.
This sander features upgraded power compared to previous models for even greater service life; the body of the machines houses a 300W brushless motor for an extended service life, with soft start and electronic pad brake for controlled sanding. The variable speed has a range covering 4,000 to 10,000rpm, while the 5mm oscillation offers high stock removal rates. The updated design makes it easy for the operator to adjust the sanding speed, as LED indicators are located on the speed selector, together with a separate on/off switch and lockable speed for optimum control.
It has the lowest vibration values in its class. You can monitor vibration levels in real-time with the myMirka app, which uses enhanced Bluetooth technology to track your vibration levels.
The Deco kit which comes with the DEROS II 350V includes:
50 x Abranet® ACE discs grit P80
50 x Abranet® ACE discs grit P120
50 x Abranet® ACE discs grit P180.
2+1 Extended Warranty for Mirka sanders, registration required within 30 days.
Warranty Mirka 3 Year Warranty (Registration Required)
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
Registration is required within 30 days of purchase. More information can be found on the Mirka warranty website and in the warranty conditions.
For warranty issues outside of the UK, tools must be returned to the UK and carriage charges would be at the customer's own cost.
Register your product now
5.00 1
