PROXXON Diamond Coated Cutting & Roughing Disc for LHW & LHW/A Grinder
- Diamond coated disc for cutting and grinding
- Suitable for hard materials; glass, porcelain and ceramics
- Cooling holes minimise heat build-up
- Fits long neck angle grinders LHW and LHW/A
- 50mm diameter with 10mm bore
This 50mm diameter diamond coated disc has a 10mm bore. Used for cutting, grinding and roughing of hard materials such as glass, porcelain, ceramics and stone. The cooling holes help minimise heat build-up. It is suitable for the PROXXON long neck angle grinders LHW and LHW/A.
Bore Size | 10 mm |
Disc Diameter | 50 mm |
EAN Barcode | 4006274285576 |
- Standard Delivery* - £1.99
