PROXXON MBS 240/E Micro-Bandsaw
474198
From £344.98 £287.48
15 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 10th Jun
  • Solid, ribbed die-cast aluminium housing
  • Double ball bearing aluminium pulleys
  • Sturdy 200 x 200mm machined table with slot for mitre gauge
  • Table tilts to 45° for accurate mitre sawing
  • Low noise 230V motor
  • Electronic speed is control
  • Standard equipment includes 1,065 x 5.0 x 0.4 mm (14 TPI) band saw blade
  1. PROXXON MBS 240/E Micro-Bandsaw
Total:
£804.12 £670.10
The MBS 240/E has a solid, ribbed die-cast aluminium housing and features double ball bearing aluminium pulleys. Its sturdy, machined table with slot for mitre gauge measures a generous 200 x 200mm. The table tilts through 45° for accurate mitre sawing. The machine is powered by a low noise 230 Volt motor (high quality, for quiet, prolonged use) with toothed belt drive. The speed is controlled electronically for exceptionally accurate cutting. A clear table indicates the recommended speed for most materials. The blade size (5.0 x 0.4 mm) is ideal for fine work, allowing cutting of small radii. Standard equipment includes one 1,065 x 5.0 x 0.4 mm (14tpi) band saw blade. A diamond blade is available for cutting glass and ceramics.
4.10 15
