PROXXON MBS 240/E Micro-Bandsaw
- Solid, ribbed die-cast aluminium housing
- Double ball bearing aluminium pulleys
- Sturdy 200 x 200mm machined table with slot for mitre gauge
- Table tilts to 45° for accurate mitre sawing
- Low noise 230V motor
- Electronic speed is control
- Standard equipment includes 1,065 x 5.0 x 0.4 mm (14 TPI) band saw blade
The MBS 240/E has a solid, ribbed die-cast aluminium housing and features double ball bearing aluminium pulleys. Its sturdy, machined table with slot for mitre gauge measures a generous 200 x 200mm. The table tilts through 45° for accurate mitre sawing. The machine is powered by a low noise 230 Volt motor (high quality, for quiet, prolonged use) with toothed belt drive. The speed is controlled electronically for exceptionally accurate cutting. A clear table indicates the recommended speed for most materials. The blade size (5.0 x 0.4 mm) is ideal for fine work, allowing cutting of small radii. Standard equipment includes one 1,065 x 5.0 x 0.4 mm (14tpi) band saw blade. A diamond blade is available for cutting glass and ceramics.
| Bandsaw Blade Length | 1,065 mm (42") |
| Blade Speed | 180 - 330 m/min |
| EAN Barcode | 4006274271722 |
| Max Cutting Height | 85 mm |
| Max Width of Cut | 150 mm |
| Model | MBS 240/E |
| Motor Power | 80 W |
| Nett Weight | 7.5 kg |
| Overall L x W x H | 510 mm x 432 mm x 330 mm |
| Rating | Home/Light Trade |
| Sound Pressure Level LpA [Uncertainty K] | 70 dB(A) [3.0 dB] |
| Table Size | 200 mm x 200 mm |
| Table Tilt | 0° - 45° |
| Voltage | 230 V |
- Standard Delivery* - Free
