PROXXON TBH Bench Drill
702069
From £416.98 £347.48
5 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Friday 11th Jul
  • Height adjustment easily altered with headstock lock lever
  • Table features ribbed base and milled work area with T-slots
  • Permanent magnet motor
  • Max drill bit size 10mm
  • Three speeds 1,080, 2,400 & 4,500rpm
  1. PROXXON TBH Bench Drill
Total:
£958.92 £799.10
The table and arm of the PROXXON TBH drilling machine are made of die-cast aluminium. A refined, rust-proof and statically very solid material. Fittings and feeds are machined on CNC controlled machines (milled, line-bored, lathed, etc.). Practical height adjustment via toothed rack with easy to operate crank. The table features a ribbed base and milled work area with T-slots. The column is bright nickel-plated. Powerful, long life 230V permanent magnet motor. The quill is driven via a belt and three step pulleys. This yields a torque multiplication of as much as 6x at the lowest speed. Geared quill feed for exact operations runs in ball bearings. Spindle with 1/2"' thread accepts the industrial standard ROHM chuck.
4.80 5
