Veritas Hand Jointer
106744
From £47.38 £39.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Dispatching Soon
- Email me when available
  • Accurately joint small parts by hand
  • Takes the work to the plane rather than plane to the work
  • Fits the Veritas medium or large shoulder planes
  • Low-friction HDPE fence
  • Easy to set up, use vertically or horizontally
  • Safe and controllable way to joint small parts
  1. Veritas Hand Jointer
Total:
£319.72 £266.43
Box and model making often require small parts that are too dangerous to run through a power jointer and difficult to joint with a hand plane. Trying to balance a large plane on a small workpiece can be awkward. This hand-jointing accessory fits the Veritas medium and large shoulder planes. It allows you to bring the work to the plane, giving you much greater control of the cut.
The jointer board is 255mm x 240mm and 18mm thick Baltic birch ply, with a 250mm x 50mm low-friction HDPE (high-density polyethylene) fence. The fence makes it easy to align the work square to the blade. The mounting holes let you attach either of the Veritas shoulder planes for right or left-hand use. A large brass knob firmly secures the plane. The board provides plenty of surface area for clamping the hand jointer horizontally to a benchtop or vertically in a vice.
It also includes a recess with an inset rare earth magnet for holding a spare blade; useful for storing a blade sharpened at a higher bevel angle to deal with highly figured wood. This is a safe and highly accurate way to joint small parts.
