Arbor for 10mm Bore Polishing Mops
- Enables mops to be used in a power drill or flexible shaft
- For use with 10mm bore metal centred mops
- 6mm shank
- Recommended mops no more than 100mm diameter
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price £69.97 £58.31 was £89.98 £74.98 Save £20.01 £16.67
This arbor enables 10mm bore metal centred polishing mops to be mounted in a power drill or flexible shaft. It has a 6mm shank to fit into the drill's chuck. Please note, when using a polishing mop in a drill or flexible shaft, it is recommended to use mops no more than 100mm in diameter.
EAN Barcode | 5060030665872 |
- Standard Delivery* - £1.99
