Armeg Adjustable Hole Cutter 40 to 200mm
952812
Special Price £67.85 £56.54 was £75.38 £62.82 Save £7.53 £6.27
4 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Wednesday 28th May
  • Clear polycarbonate impact resistant dust shield,
  • Fitted with large ball race bearing for smooth running
  • Two cutting blades, cutting diameter from 40 to 200mm
  • Graduated cutter arms for simplified set up
  • Maximum thickness of material 46mm
  • Suitable for plaster board, plywood, hardboard, veneers, acrylic
  1. Armeg Adjustable Hole Cutter 40 to 200mm
Total:
£284.89 £237.41
The clear polycarbonate dust shield has two main functions. It collects debris, dust and chippings, which is particularly important when working overhead. It also acts as a guide ensuring that the drill bit is always at right angles to the work surface. The boring head passes through a large ball race bearing so runs very smoothly. Two cutters, one on each of the graduated arms gives you a balanced performance minimising vibration. The cutting depth is adjustable up to a maximum of 46mm. The ability to bore holes from 40 to 200mm diameter allows you great versatility. Use with a variable speed drill, the larger the diameter the slower the speed.
5.00 4
