Axminster Model Engineer Series MCB115SHD Swivel Head Bandsaw
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- All cast iron frame and bed; 3 speed belt drive
- Quick release head swivels from -45° to +60°
- Hydraulic downfeed control with infinitely variable adjustment
- Adjustable length stop
- Automatic downfeed stop
- All ball bearing blade guides
- Ideal for the smaller fabrication jobs, especially those which require materials accurately cut at various angles
Axcaliber M42 Premium Bandsaw Blade 1,640mm(64.1/2") x 12.7mm 10-14 TpiFrom £36.28 £30.23
Axcaliber High Carbon Bandsaw Blade 1,640mm(64.1/2") x 12.7mm 24 TpiFrom £12.88 £10.73
A versatile, medium sized metal cutting bandsaw with several notable features. This machine will be ideal for the smaller fabrication jobs, especially those which require materials accurately cut at various angles. Made predominately of cast iron, this machine features a swivelling head, which is a much more accurate and convenient method of cutting bevels or angles than the more usual pivoting vice jaws. Cutting pressure is set on the hydraulic support ram, whilst 3 belt speeds allow the correct speed for the job to be selected.
The material vice has a large capacity, and features a quick release mechanism to allow fast setting.
The floor stand has a pair of wheels at the rear, which allows easy mobility when you slide out the handle, but also offers a stable platform in use.
Well finished and reliable, this has proved to be a very good small bandsaw.
Axminster Model Engineer 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Model Engineer machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Bandsaw Blade Length | 1,640 mm (64.1/2") |
Base Size | 475 mm x 337 mm |
Blade Speed | 23, 34 & 54 m/min |
Blade Width | 13 mm |
EAN Barcode | 5052511036547 |
Max Cap @ 45º | 76 mm x 90 mm or 90 mm round |
Max Cap @ 60º | 50 mm x 56 mm or 50 mm round |
Max Cap Rectangular | 100 mm x 150 mm |
Max Cap Round | 125 mm |
Model | MCB115SHD |
Nett Weight | 87 kg |
Overall L x W x H | 1,079 mm x 442 mm x 1,350 mm |
Plug Fitted | UK 3 pin plug |
Power | 560 W |
Rating | no value |
Table Height | 740 mm |
Voltage | 230 V |
- Standard Delivery* - Free
