Axminster Professional Dado Blade Table Insert
- Table insert for AP254SB when using dado blade
- Replaces standard table insert
- Aluminium with 25mm wide slot
Trend Tool and Bit Cleaner - 532mlSpecial Price £14.78 £12.32 was £16.78 £13.98 Save £2.00 £1.67
Axminster Professional 200mm Dado Blade SetFrom £199.98 £166.65
This table insert fits the AP254SB Professional Saw Bench. It is required when using a dado blade, replacing the standard insert. The slot is 25mm wide to accommodate the dado blade. It is used with the saw blade set at vertical only. Made from aluminium.
EAN Barcode | 5052511131471 |
- Standard Delivery* - £1.99
