Axminster Workshop AW1400B Bandsaw - 230V
107710
From £199.98 £166.65
Available to Backorder
- dispatch estimate is within 2 weeks. Delivery info
  • 80mm depth of cut - 200mm width of cut
  • Compact machine perfect for hobbies and crafts
  • Rigid, quick locking rip fence, doors fitted with safety switches
Perfect for small to medium woodworking projects
The Axminster Workshop AW1400B Bandsaw weighs in at 20kg, making it the smallest bandsaw in our Axminster Workshop range, and is packed with features not normally found on a saw of this size.
Buy with confidence
So sure are we of the quality of this saw, we cover all parts and labour free of charge for three years! Find out more
Why this bandsaw deserves to be in your workshop...
A space saving solution
The small, compact size allows you to save valuable floor space and can be easily stored or moved to one side when not in use.
Bearing Guides
New and improved top and bottom bearing guided blade system provides improved accuracy and easy set up. The top guide has a height adjustment, allowing max 80mm depth of cut.
Increased cutting accuracy
Similar to the larger bandsaws in the Axminster Workshop range is the wide, curved steel chassis. This design gives you excellent tension on the blade to increase the cutting accuracy!
Easy access
The keyless opening on the door means you can access inside your bandsaw with a simple twist of the knob.
Stable and robust
The bandsaw’s table is finely ground, solid cast iron and tilts from 1 to 45 degrees. This enables your work to glide effortlessly through the machine, allowing you to take on larger projects with peace of mind.
Optional mitre fence available
Made of cast alloy, the mitre fence allows you to produce accurate crosscuts at any angle. With clear markings and a slot for attaching a sacrificial fence, this is a very useful addition to the bandsaw.
How to get the best out of your AW1400B
Learn how to set it up for accurate cuts
Our experts show you everything you need to know, right through to making your first cut!
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Shop 1,400mm bladesRead our buying guide
  1. Axminster Workshop AW1400B Bandsaw - 230V
Total:
£241.52 £201.27
The Axminster Workshop AW1400B bench mounted bandsaw is designed for the small workshop and easily moved when not in use.
It features a strong welded steel chassis with a cast iron table. It will take blades from 4.8 to 9.5mm wide. Bearing blade guides and thrust bearing provide maximum blade control for improved accuracy over similar entry level bandsaws. The top guide blade has a rack and pinion height adjustment, giving a maximum of 80mm depth of cut.
It has a direct drive motor and balanced cast alloy wheels. The top wheel is mounted in a welded steel sub frame with blade tensioning and tracking controls conveniently close.
A single dust outlet port provides efficient dust removal when connected to a suitable vacuum extractor, which must be recommended for increased cutting performance.
The machine is supplied with a 6mm x 6tpi general purpose blade made from UK manufactured stock. A selection of different blades are available to suit many jobs.
An optional mitre fence is available to fit this bandsaw (sold separately).
This is a superb small bandsaw for a hobby or craft workshop or as an additional machine for smaller work.
Warranty Axminster Workshop 3 Year Guarantee
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
4.50 247
