Festool Granat Abrasive Discs 225mm
From £35.38 £29.48
  5. Half Star
2 Reviews
  • Hard aluminium oxide and ceramic grit, long lasting
  • Resists clogging and smearing, high quality surface finish
  • Multi-Jetstream hole-pattern significantly improves dust extraction
  • Excellent product to use on filler, paint and drywall compound
  • 225mm diameter, suitable for Planex Drywall Sander
  • Effective on scratch resistant coatings and high VOC coatings
Festool Granat abrasive is composed of hardened aluminium oxide and ceramic grits. Festool Granat offers aggressive stock removal to superfine, finish sanding. It is particularly effective on scratch resistant coatings, hard surface paints and high VOC coatings. This high tech abrasive is resistant to clogging and smearing, it lasts longer and results in a smooth even surface finish. Engineered and manufactured to strict FEPA standards, Festool Granat abrasive guarantees a uniform abrasive coating and consistent sanding results. For sanding most modern paint systems, VOC clear coats, plastic materials, mineral materials and acrylics, Festool Granat achieves consistent, high quality results. 225mm diameter, suitable for Festool Planex Drywall Sander.
4.50 2
