Festool 260mm TCT Saw Blades
- Festool 260mm saw blades, 30mm bore
- 80T blade for clean and splinter-free cross cuts in solid wood
- 60T blade for general purpose use, wood and soft plastics
Trend Tool and Bit Cleaner - 532mlSpecial Price £14.78 £12.32 was £16.78 £13.98 Save £2.00 £1.67
260mm saw blades for the Festool KS 120 and KS 88 compound sliding mitre saws. Various options available; 80 teeth crosscut tooth saw blade for clean and splinter-free cross cuts in solid wood as well as for coated or veneered panels. 60T Blade for general purpose use, wood and soft plastics.
Blade Diameter | 260 mm |
Bore Size | 30 mm |
Hook Angle | 5° Negative Rake |
Kerf | 2.5 mm |
Maximum RPM | 5,800 rpm |
Plate Thickness | 1.8 mm |
Tooth Format | ATB |
