The DS400D is a double position brazing hearth, supplied with two easy-to-use single valve controlled RF80 torches which allow one hand operation. Equipped with a solid refractory hearth with robust side, central and rear heat shields.
The DS400D has a high safety rating and complies with British Gas standards and is a fully fail safe system. All sequences are visually displayed using neon indicators. On startup the gas train, hoses and torches are tested for escaping gas. Leaks from any component will result in a continuously illuminated red neon and the main flow of gas will be prevented from entering the system.
This product is classified as an Enquiry product. Enquiry
products require contact with our friendly team prior to
purchase to understand your requirements. Typically these products have many
customisation options or require product training.
Enquiry products are usually readily available and often despatched directly
from the manufacturer using the best delivery service available. Despatch
times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact customer services for more information.
