KNIPEX CoBolt ® Compact Bolt Cutters Multi-Component Grip 200 mm
- Lever action mechanism for low friction
- Cutting performance 20 times higher than hand force
- Ideal for piano wire, bolts, nails, rivets, and screws
- Induction-hardened cutting edges for durability
- Edge hardness approximately 64 HRC
- Exceptional cutting with minimal effort
The KNIPEX CoBolt®Compact Bolt Cutters have a lever action mechanism which guarantees an extremely favourable lever ratio with low friction, and cutting performance is 20 times higher than the hand force applied (requires 60 % less effort). CoBolt®; compact bolt cutters are ideal for piano wire or for soft solid wire, bolts, nails, rivets and screws. Induction-hardened and with precision cutting edges. Edge hardness approximately 64HRc for added strength and durability, they have exceptional cutting performance with minimal physical effort because of the lever action.
EAN Barcode | 4003773052289 |
- Standard Delivery* - Free
