PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The Mafell PSS3100SE is a unique rail-guided, portable, automatic panel saw. The PSS3100SE brings all the advantages of a large static panel saw in a package that can be easily transported. The guide rail can be separated into two and the whole unit weighs less than 18.5kg.
With a cutting length up to 3,100mm and cutting depth of 45mm it is ideally suited to processing sheet and board materials, wherever it’s needed.
The saw and rail system can make plunge cuts or stopped cuts. It has a scoring feature for splinter free results in coated boards. Blades are available to suit a wide variety of materials from plywood and OSB to gypsum and cement board. The rail features non-slip inserts on the underside and does not require clamps.
The blade speed and feed rate are selected on the control pane, then you just press the rocker switch and the saw does the rest. At the end of the cut press the opposite side of the rocker switch and the saw automatically returns to the starting point.
Since you remain at the control point the PSS3100SE is safe to use. It includes an automatic riving knife that drops into place once the blade has reached the cutting depth.
Dust extraction is highly effective. The innovative blade guard in conjunction with the integrated suction channel in the rail eliminates practically all dust when connected to a suitable vacuum extractor.
This product is classified as a Dropship product. Dropship products are usually
readily available and despatched directly from the manufacturer using the best delivery service
available. Despatch times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact
customer services
for more information.
