PROXXON TG 125/E Disc Sander & Self Adhesive Discs - PACKAGE DEAL
717734
717734
From £179.98 £149.98
  5. Half Star
6 Reviews
Dispatching Soon
- Email me when available
Delivery
Free Standard Delivery*.
Dispatch estimate is within 5 weeks.
  • PROXXON TG 125/E Disc Sander
  • For all wood types, steel, non-ferrous metals, precious metals, plastics (also Plexiglas and glass fibre)
  • Powerful and vibration-free running due to balanced DC motor
  • Can be table mounted
  • Housing in glass fibre reinforced casing
  • Aluminium table, adjustable from +50° to -10°
  • Fitted with dust extraction for connection to vacuum
  • PROXXON Self adhesive Corundum Sanding Discs for TG 125/E
  • Self adhesive Corundum Sanding Discs
  • Industrial quality
  • For sanding soft and hard woods, laminates, non-ferrous metals, steel, plastics, cork, rubber and minerals
  • 125mm diameter
  • 150 & 240 grit
  • Packs of 5
  • Includes silicone film for storage and re-use
  • Show More
  1. PROXXON TG 125/E Disc Sander & Self Adhesive Discs - PACKAGE DEAL
Total:
£335.22 £279.35
This package comprises the PROXXON TG 125/E Disc Sander and the 150 and 240 grit PROXXON Self adhesive Corundum Sanding Discs.
The TG125/E is a precision device for fine sanding work and minor material correction. It features electronic speed control giving the range 250 to 800m/min. It is suitable for all wood types, steel, non-ferrous metals, precious metals, plastics (also Plexiglas and glass fibre). The sander is both powerful and vibration-free running thanks to balanced DC 140W motor, housed in a glass fibre reinforced polyamide case. The 140 x 98mm table is aluminium, adjustable to 50° incline downwards, 10° upwards. The 125mm diameter disc has a glued-on silicon film. This surface ensures that self adhesive sanding discs can be removed without problems after use. Two additional quadratic silicon films ensure that used discs can be stored and reused. A suction channel allows connection to a vacuum for dust-free working. Supplied with two sanding discs of each grit: 80, 150 and 240grit. The machine can also be used vertically (clamped for safety) for sharpening tools etc.
Self adhesive Corundum Sanding Discs for TG 125/E. Industrial quality. For sanding soft and hard woods, laminates, non-ferrous metals, steel, plastics, cork, rubber and minerals. Diameter 125 mm. One square silicone film for storage and reuse of used sanding discs is included. Supplied in 150 and 240 grit, packs of 5 of each.
4.70 6
