PROXXON WP/E Angle Polisher
- Perfect finishing, even in tight spots
- Used for polishing, cleaning, sanding and light rust removal
- Powerful DC motor with continuously variable speed
- Die-cast aluminium gear housing
- Complete with a range of accessories
- Polypropylene storage case
PROXXON tools come with a reputation for quality and this small angle polisher is no exception. It uses a quiet, powerful DC motor with continuously variable speed control (full-wave electronics) for low and constant speeds even during high contact pressure. Motor power is transferred to the planetary gearing which is contained in a robust, die-cast aluminium housing. The main body of the machine is made from glass-fibre reinforced POLYAMIDE with a softer section on the underside making it more comfortable to hold. Supplied with a rubber backing disc with hook and loop fastening, polishing sponge (medium hard), lambswool polishing disc, polishing felt for metals and non-ferrous metals (medium hard), 12 sanding discs K 2000 and NIGRIN, polishing emulsion (75ml) as well as a microfibre cloth. The polisher and accessories are stored in a stylish polypropylene case with a handle and two snap closures, ready for immediate use.
Corded or Cordless | Corded |
Disc Diameter | 50 mm |
EAN Barcode | 4006274286603 |
- Standard Delivery* - Free
