Shaper Plate Universal Template for Shaper Origin
- Universal template for Shaper Origin CNC router
- Replaces hundreds of individual templates
- Multitude of digital files available on ShaperHub
- Fast to set up and endlessly flexible
- Bring precision cutting to any project
- System 32 Ready
Shaper Plate; an amazing accessory for the Shaper Origin CNC router. Shaper Plate literally replaces hundreds of individual routing templates. This universal template works seamlessly with ShaperHub's Hardware Catalogue, for access to hundreds of digital routing files.
Shaper Plate is perfect for installing common hardware, routing hinge pockets for Euro cabinet hinges, mortices for butterfly keys, 32mm system shelf holes, small carvings or engravings from hundreds available in the Shaper Hub database.
Setting up the Shaper Plate is fast; simply mark the work piece and then align with the retractable fence. Cleverly designed clamps and an anti-slip mat on the underside ensure the Shaper Plate stays put. The Shaper Plate features built-in ShaperTape so it’s ready to use, again and again.
The cut window is 160mm x 120mm. Multiple pop-up ''flags'' (stops) and the adjustable fence make it simple to align perfectly with marks on your workpiece. Import your chosen file from the Shaper Hub catalogue and let your Shaper Origin guide you.
Shaper Plate includes a System 32 pin for producing 32mm hole spacing with perfect alignment.
Includes 2 low profile clamps with 60mm capacity
Plate dimensions: 362mm x 450mm x 6.35mm
Plate Weight: 2,040g
Cut Window: 160mm x 120mm
Clamp Throat Depth: 60mm
EAN Barcode | 859790007504 |
Model | SV1-AA |
- Standard Delivery* - Free
