Shaper Origin Handheld Precision CNC Router
109356
From £3,299.00 £2,749.17
3 Reviews
Shaper Origin Offer; SAVE, Extra Warranty Now 3 Year & FREE Mini Systainer, 2 Pairs of Reversible Clamps, Woven Hose, Pry Bar and Scraper. Direct from Shaper 4 Premium Project Plans added on machine registration with Shaper.
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Wednesday 2nd Sep
  • Portable, precision CNC routing anywhere any time
  • Featuring a large screen
  • Engineered by Shaper; assembled by Festool
  • Limitless possibilities packed into a Systainer case
  • On-tool CAD or import designs via USB or wirelessly
Discover the Shaper Origin
Designed and engineered by Shaper and assembled by Festool in Germany.
Supplied with two-year warranty
Innovative
Shaper Tools’ approach to handheld CNC routing will change the way you work. Features include a very clear 5.5’ high-resolution screen.
Simple
Incredibly easy to use, with its on-tool CAD features. Programme basic shapes or import more advanced drawings via the onboard software. Next, apply Shaper tape to your workpiece, scan with Origin and you are ready to start cutting.
Versatile
The Shaper Origin can be used for an array of different jobs, including joinery, flooring, engraving, and more. Equipped with Jenner software, further extensions are available.
Compact and portable
Easy to control, being similar in size to a half-inch router. Supplied in a T-Loc systainer for easy transportation.
Efficient
Able to make intricate, accurate cuts in minutes. The Origin guides you, allowing you to work more quickly than when you would when cutting unaided. With full auto correction for the movement of your hands, it guarantees precise results every time.
Support
All Origin owners will have access to the Shaper Hub. Thousands of designs are stored here, some uploaded from other Shaper customers. Shaper Tools also have a dedicated phone line if you need assistance with your unit.
Shaper plate
A universal template that works seamlessly with ShaperHubs's Hardware Catalogue, for access to hundreds of digital routing files. Featuring a built-in ShaperTape so you can use it again and again.
This Shaper Origin handheld precision CNC router offers unparalleled accuracy, flexibility and efficiency. Shaper Origin features a larger 5.5” high resolution screen, a 25% increase in size. The entire assembly is now housed in a sleek, super strong aluminium unibody construction. The Shaper Origin, literally puts CNC routing at your fingertips.
Designed and engineered by Shaper and assembled by Festool in Germany, this machine puts all the benefits and advantages of CNC routing into any workshop. Packed into a Systainer3 case the Shaper Origin neither takes up large amounts of floor space nor is the size of the workpiece restricted. Being handheld, the Origin can be used in virtually any workshop and anywhere else. Take CNC routing to the job, work onsite on any size of project; on floors, in kitchens, onboard boats, literally anyplace.
The Shaper Origin saves time spent in producing templates as the template is stored in the machine’s memory, allowing you to get straight on with the job. This machine offers limitless possibilities. Create complex joinery, intricate inlays, fine engraving, decorative parquet flooring, lettering and sign writing
Like any CNC machine, pre-programmed computer software dictates the movement of tool. Origin features precision X, Y and Z axes with automatic tool tip detection. The large screen displays the path of the design for you to follow, the really clever bit is the full auto correction for the movement of your hands guaranteeing precise results every time.
The on-tool CAD (Computer Aided Design) features means you can draw basic shapes right into the Origin. There’s also the option to import more advanced and technical drawings to the machine via a USB stick, or wirelessly.
The Shaper Origin is supplied with Jenner Software and comes packed in a T-Loc Systainer with: 3mm Up-Spiral router bit, 6mm Up-Spiral router bit, 60° V engraving router bit, 2 x rolls of shaper tape and wrenches.
Please note: Shaper’s product lineup will officially move into the Festool portfolio beginning in 2027. New purchases made between August 1 and October 31st will be covered by Festool’s standard three year warranty.
NB. This tool is only available for delivery to mainland UK
Warranty Shaper 2 Year Warranty (Registration Required)
Shaper 2-Year Warranty (registration required)
Upon purchase, you will receive an email to register your tool to receive a two-year warranty.
Benefits include:
  • A 24-month machine guarantee
  • Full repair of your machine, free of charge
  • A dedicated live support phone line, direct to Shaper Tools.
  • If the support team cannot solve the problem, the customer will receive a replacement.
For more information and enhanced warranty options with Shaper Pro Care, click here.
Please note: Axminster Tools cannot register a Shaper tool on a customer’s behalf. For more information, please visit Shaper’s warranty section.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
5 3
