Stanley FatMax XL Retractable Blade Utility Knife
- Retractable blade die-cast aluminium utility knife
- Chunky brass wheel blade lock gives positive blade lock
- Supplied with 10 spare blades
A retractable blade utility knife with a die-cast aluminium housing that combines maximum strength with amazing lightweight properties. Solid, secure handling is provided by the extra-large handgrip and the diamond-shaped textured handle ensuring a sure-grip whatever the conditions and allowing for work with gloved hands. Able to hold up to 15 blades and with no tooling required for blade changing down time is kept to a minimum. The chunky Brass wheel blade lock gives a positive blade lock and allows you to control the width of the knife opening, giving you a sure feel when using extra heavy duty blades. A sprung-loaded swivel opens the knife wide for quick and easy blade change, plus the magnetic nose holds the blade in place whilst it’s being changed. Supplied with 10 spares blades. 205mm in length.
EAN Barcode | 3253565108194 |
- Standard Delivery* - £1.99
