Veritas Optional Set of 6 Shims for Domino Table
109387
From £26.98 £22.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Set of 6 comprises 2 each; 2mm, 4mm and 8mm
  • Creates vertical offset on Veritas Domino Joinery Table
  • Allows adjustments of 1mm increments
  • Made in Canada
  1. Veritas Optional Set of 6 Shims for Domino Table
Total:
£58.94 £49.12
These shims are used on the Veritas Domino Joinery Table. This set of six comprises two each; 2mm, 4mm and 8mm. The shims are used to raise the Festool Domino DF 500 to create the vertical offset for your project requirements. The shims fit either into the slots in the milled cavity for the Domino base plate, or they can be placed on each side of the cavity. This allows adjustments to be made of 1mm increments, depending on the desired vertical offset of the mortice.
Made in Canada.
