UJK Drill Table & Fence for Pillar Drills
106702
From £231.98 £193.32
  5. Half Star
29 Reviews
  • Increases the work area, better support for large woodworking pieces
  • Fits all Axminster Profesional Pillar Drills
  • Makes drilling safer and more precise
  • 26mm MDF table, 595 x 395mm in size
  • Full length aluminium fence, adjustable fence plates and repeat stop
  • L&R scales and rear dust extraction port
  • Reversible to suit a wide range of pillar drills
  • Toggle clamp system for ease of fitting or removal
  • Two toggle clamps included
Most pillar drills are designed for metal working processes rather than woodworking. This UJK Pillar Drill Table will enhance your pillar drill, supporting the workpiece for better drilling accuracy or delicate sanding or shaping tasks. Made from 26mm thick MDF it features an aluminium extrusion fence with sliding sub faces, a dust port for drum sanding extraction and a flip over length stop for repeat hole positioning. A sacrificial plate protects the centre area.
The fence slides on twin T tracks, into which you can also mount clamps. The sub faces give extra support for long pieces, whilst there is a combined RH/LH scale for the flip over stop.
There are a couple of clever features of note, the sacrificial plate is slightly offset, the whole table is reversible so that an extensive range of machine throat depths can be accommodated. The other lies underneath; there are two bars which have three alternative mounting positions, giving a width range of between 310mm-490mm. There are two toggle clamps with 50mm of adjustment, so almost all pillar drills can have this table mounted. Once the mounts are set to your machine, it takes seconds to lift this table on or off.
One final twist is the optional V block, which bolts in place of the sacrificial plate, allowing cylindrical parts to be drilled. There is a centre hole to allow accurate positioning.
Convert your pillar drill into a machine much better suited to woodworking with this nicely designed table. The drill table fits all Axminster professional Pillar Drills: AP340PD (code: 107704), AT325PD (code: 107705), AT700PD (code: 107706), AT540PD (code: 107707).
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.41 29
