Amana 4 Piece CNC Simulated MDF Shaker Door Set
- 4 piece set
- 1/4" shank
- Produce Shaker door appearance
- Designed for wood, MDF, veneered plywood & laminate
Amana 8 Piece General Purpose CNC Router Cutter Set AMS174 1/4" ShankSpecial Price £169.87 £141.56 was £208.18 £173.48 Save £38.31 £31.92
Amana 3 Piece Starter Engraving SetSpecial Price £215.57 £179.64 was £264.18 £220.15 Save £48.61 £40.51
Amana 8 Piece General Purpose CNC Router Cutter Set AMS134 1/4" ShankSpecial Price £140.90 £117.42 was £172.68 £143.90 Save £31.78 £26.48
Amana 8 Piece General Purpose CNC Router Cutter Set AMS177K 1/4" ShankSpecial Price £142.45 £118.71 was £174.58 £145.48 Save £32.13 £26.77
Amana Master CNC Router Cutter Set with Display & 57 CuttersSpecial Price £1,673.60 £1,394.67 was £2,050.98 £1,709.15 Save £377.38 £314.48
Amana Carbide Insert Spoilboard Router Cutter 1/2" ShankSpecial Price £157.80 £131.50 was £193.38 £161.15 Save £35.58 £29.65
Amana Carbide Tipped Spoilboard Router Cutter 1/4" ShankSpecial Price £22.26 £18.55 was £27.28 £22.73 Save £5.02 £4.18
This set is to produce the appearance of Shaker doors, using CNC technology. It includes the following cutters:
CNC Solid Carbide Spektra™ Extreme Tool Life Coated Compression Spiral 1/4 Dia x 7/8 x 1/4 Inch Shank
Solid Carbide Spektra™ Extreme Tool Life Coated Spiral Plunge 1/8 Dia x 1/2 x 1/4 Inch Shank
Solid Carbide 3 Flute V-Groove 60 Deg x 1/4 Dia x 7/32 x 1/4 Inch Shank Spektra™ Extreme Tool Life Coated Router Bit
Carbide Tipped Spoilboard Surfacing, Rabbeting, Flycutter, Slab Leveler, Surface Planer & Flattening 1-1/8 Dia x 1/2 x 1/4 Inch Shank Router Bit
Ideal for producing Shaker doors in MDF or solid panels, this set is suitable for use on all of the following materials:
Aluminum, Brass, Bronze, Copper
Carbon Fiber
Laminate
MDF
Melamine
Plastic/Acrylic
Solid Surface
Wood
Veneered Plywood
This set is only for use with a CNC router and shouldn't be used with a handheld router.
EAN Barcode | 738685002636 |
- Standard Delivery* - Free
