Axcaliber Contract 250mm Thin Kerf TCT Saw Blades
- Generously sized tips brazed onto tensioned quality steel plates
- Thin kerf technology, perfect for mitre saws
- Less waste required & less power needed
- True running blades for the perfect cut
Trend Tool and Bit Cleaner - 532mlSpecial Price £14.78 £12.32 was £16.78 £13.98 Save £2.00 £1.67
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find a blade to suit every requirement. Bore size 30mm. Thin kerf blades offer the advantage of less power being required to produce a cut, especially useful for mitre saws and brush motor powered bench saws. You should check that your riving knife can accommodate a thinner than standard blade. N.B. Bore reducing bushes are not suitable for use with these blades.
Blade Diameter | 250 mm |
Bore Size | 30 mm |
Kerf | 2.1 mm |
Maximum RPM | 7,600 rpm |
Plate Thickness | 1.2 mm |
Tooth Format | ATB |
