Axcaliber Pack Of 5 Bandsaw Blades For AT3352B
- Pack of 5 x 3,352mm bandsaw blades
- For the AT3352B bandsaw
- Pack comprises 1 each of:
- 1/2" x 6 tpi Ground Tooth
- 3/8" x 4 tpi Ground Tooth
- 1/4" x 6 tpi Ground Tooth
- 3/4" x 3 tpi Ground Tooth Freshcut Blade
- 3/4" x 4 tpi Ground Tooth Freshcut Blade
Trend Tool and Bit Cleaner - 532mlSpecial Price £14.78 £12.32 was £16.78 £13.98 Save £2.00 £1.67
A pack of 5 x 3,352mm bandsaw blades for the AT3352B bandsaw. Comprises 1 x 1/2" x 6tpi GT, 1 x 3/8" x 4tpi GT, 1 x 1/4" x 6tpi GT, 1 x 3/4" x 3tp Freshcut, 1 x 3/4" x 4tpi Freshcut.
Ground Tooth blades have diamond ground super sharp teeth and work extremely well in all wood giving a high feed rate with exceptionally high quality finish and clean cut and long life.
Freshcut 37 GT Straight Cut bandsaw has precisely ground diamond super sharp teeth with a light set which gives a narrow kerf and reduces the waste produced whilst the hook configuration provides maximum penetration. Perfect for ripping all types of timber, producing veneers and boards.
Bandsaw Blade Length | 3,352 mm (132") |
Bandsaw Blade Type | Ground Tooth |
- Standard Delivery* - Free
