Axminster Professional Twist & Fix 100mm Stitched Polishing Mop
- Stitched to give a firmer working surface
- Second stage polishing steel, stainless steel and iron
- Mounts directly onto the Ultimate Edge Twist & Fix arbor
- Recommended for use with pink or white compound
Axminster Workshop Super Fine Polishing & Honing Paste 250mlSpecial Price £9.26 £7.72 was £11.58 £9.65 Save £2.32 £1.93
Axminster Workshop Medium Polishing & Honing Paste 250mlSpecial Price £9.26 £7.72 was £11.58 £9.65 Save £2.32 £1.93
Axminster Workshop Fine Polishing & Honing Paste 250mlSpecial Price £9.26 £7.72 was £11.58 £9.65 Save £2.32 £1.93
Axminster Workshop Red Polishing CompoundSpecial Price £2.95 £2.46 was £3.68 £3.07 Save £0.73 £0.61
Axminster Workshop Yellow Polishing CompoundSpecial Price £2.38 £1.98 was £2.98 £2.48 Save £0.60 £0.50
Axminster Workshop Green Polishing CompoundSpecial Price £2.38 £1.98 was £2.98 £2.48 Save £0.60 £0.50
Axminster Workshop Blue Polishing CompoundSpecial Price £2.38 £1.98 was £2.98 £2.48 Save £0.60 £0.50
Axminster Professional Final Finish Buffing PowderSpecial Price £5.42 £4.52 was £6.78 £5.65 Save £1.36 £1.13
These 100mm diameter stitched sisal mops have leather centre washers and 12mm bore for mounting onto the Ultimate Edge Twist & Fix arbor.
Stitching produces a mop with a firmer face; a stitched mop's normal usage is in the first and second (if required) stages of the polishing process. For best results use a separate mop for each different compound, mark each mop using a felt tip pen with the type of compound used. Good results obtained with pink or white compound.
Sold in pairs, both need to be used together when used with the Twist & Fix arbour.
EAN Barcode | 5052511109166 |
Mop Diameter | 100 mm |
- Standard Delivery* - £1.99
