Axminster Woodturning Lathe Centre Rack - 2MT
- Keep your 2MT Axminster woodturning centres organised
- Prevents centres becoming damaged when not in use
- Up to 6 centres stored safely and readily accessible
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
Axminster Woodturning Speed SizerSpecial Price £19.98 £16.65 was £27.68 £23.07 Save £7.70 £6.42
This strong 2mm thick, wall mounted steel rack keeps your woodturning lathe centres neatly organised. Their sharp points and sharp edges are out of harm’s way and safe from potential damage. It is so much easier to work if your accessories are in full view and to hand. The 6 holes take any 2MT centre. The rack has a tough painted finish and is pre-drilled for wall mounting. Size: L 320mm x W 55mm x H 35mm.
EAN Barcode | 5052511123810 |
- Standard Delivery* - £1.99
