Axminster Workshop AW150BB 150mm Polisher - 230V
- Sturdy polishing and buffing machine
- Twin stitched 150mm mops mounted on long spindles
- Heavy cast iron base for stability and smooth running
This is a sturdy, long shaft polisher/buffing machine, offering maximum reliability and long term performance, useful for restoring and polishing a range of materials. It takes 150mm diameter polishing mops. It runs smootly and vibration free with a cast iron base with bolt hole locations for secure bench mounting. The 1/2" (12.7mm) bore mops are secured with retaining nuts and washers rather than the usual "pig tail" spiral. Two mops are provided. Use with an appropriate compound to bring a real shine to your work.
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
EAN Barcode | 5052511125289 |
Model | AW150BB |
Mop Diameter | 150 mm |
Motor Power | 250 W |
Nett Weight | 11 kg |
Plug Fitted | UK 3 pin plug |
Rating | Home Workshop |
Spindle Speed | 2,980 rpm |
Voltage | 230 V |
- Standard Delivery* - Free
