Woodworking Wisdom
Perform | Beginner, DIY and light woodworking machinery
Perform - beginner, DIY and light woodworking machinery
Got a plank of wood sitting in the shed that you’ve always meant to turn into something? Or decking that’s seen one summer too many? Maybe you’ve wanted to start making, but haven’t yet found the confidence, or the tools, to begin. We get it, starting is often the hardest part. But once you take that first step, you’ll be on your way. Whether you're a beginner, DIYer or just need a tool for a light bit of woodwork, Perform is here to help you build skills, tackle projects with ease and bring your ideas to life.
Tools you can trust, from day one.
Perform is with you from your very first project through to your latest. Whether you're looking for woodworking tools for beginners, affordable workshop machines or reliable DIY tools, Perform makes getting started simple.
>Compact yet capable, Perform tools fit comfortably into your workspace, whether that’s a shed, garage or somewhere in between. Developed by woodworking experts, rigorously tested and produced with trusted suppliers, every tool is built to deliver dependable performance and affordable quality. Build more for less, and enjoy the important bit - making!
Beginner woodworking tools for home workshops
Perform Bench Grinders
Bench Grinder
First up, we have the PD150BG Bench Grinder. A light use grinder, perfect for general sharpening tasks, shaping metal and deburring, it features a smooth running 250W induction motor, adjustable tool rests, eye shields, spark guards and more.
Perform Drill
Drills
The PD8D Bench Drill is ideal for traditional woodworking and metalworking projects around the home. It features adjustable speed, a tilting table, an induction motor, depth stop and more for accurate, controlled drilling.
Perform Extractors
Dust Extractors
There are two dust extractors to pick from, covering more demanding extraction tasks, to light vacuum style tasks. The PD57E Dust Extractor is perfect for hooking up to high volume machines such as a lathe, to clear away dust and wood chips. Whereas, the PD50E Wood Dust Collector offers an alternative to domestic vacuum cleaners, great for use with benchtop machines.
Woodturning Tools
If you’re thinking about trying woodturning as a new hobby, Perform offers a range of tools and accessories that make getting started simple. The PD205WL Woodturning Lathe is an excellent choice for beginners. It's ideal for those new to turning or anyone looking for a compact machine for projects such as pens and small bowls.
Perform Woodturning Lathe
Perform Woodturning Tools
Built with a sturdy cast iron construction and featuring adjustable speed, plus included accessories, it offers great value for aspiring turners. Pair it with the Perform chuck, centres and turning tools for a well-equipped setup that’ll help you start creating with confidence.
Perform Benchtop Thicknesser
Planer/Thicknessers
For smaller workshops, the PD318BT Benchtop Thicknesser is a compact solution with fold-down tables to save space. A powerful motor and high-speed steel blades ensure clean, consistent finishes with ease.
Sanders
With a couple of sanders to choose from, there’s a solution for everything from fine detail work to larger shaping and finishing tasks. The PD15BDS Belt and Disc Sander is a compact benchtop machine. It's ideal for profiling, shaping, finishing and working on awkward angles, with quick and easy belt and disc changes.
Perform Belt & Disc Sander
For greater capacity, choose the PD150BDS Belt and Disc Sander. It provides a larger working area and a multi-position belt system, allowing you to use the platen vertically or horizontally for added versatility.
Saws
With a variety of saws in the range, there’s a solution for everything from first-time projects to detailed craft work.
Perform Bandsaw
Bandsaws are one of the most versatile machines for beginners, commonly used for curved cuts, resawing timber and general shaping. The PD1400B Bandsaw is a compact, easy-to-use all-rounder and an excellent first bandsaw, suitable for a wide range of cutting tasks.
Designed for versatility, the PD254TS Saw Bench handles various timber sizes with ease. Features including a soft-start motor, mitre and rip fence, and blade tilt help deliver accurate, controlled cuts across different applications.
Perform Saw Bench
Perform Slide Mitre Saw
For space-conscious workshops, the PD216SMS Slide Mitre Saw features forward-facing guide rails to reduce its footprint without compromising capacity. Its ability to make precise angled cuts makes it ideal for mouldings, trim, panelling, decking and more.
For finer, more intricate work, the PD405FS Scroll Saw is well suited to projects such as puzzles, wooden toys and crafts. Variable speed control, table tilt and a flexible shaft provide the precision needed for detailed cuts.
Perform Scroll Saw
Work-holding Tools
For those awkward tasks or jobs away from the workshop, portable work-holding equipment can make all the difference. The Perform Quick Bench is a compact, portable workstation with an impressive 1,000kg load capacity. It folds down neatly into a lightweight carry bag for easy transport and storage.
Perform Quick Bench
Perform Quick Clamp
The Perform Quick Clamp combines strength with portability, making it ideal for everything from everyday clamping tasks to use as a mobile workstation. Offering a 1,000kg clamping force and a generous 1,050mm capacity it’s capable of handling larger projects.
Finally, the Perform Fold Flat Roller Stand is an excellent support for machinery. Built to handle up to 80kg, it handles larger pieces of timber with ease and is a great help in the workshop for those more challenging projects.
1 year warranty
Peace of mind comes as standard, with every eligible Perform machine backed by our highest level of support. No registration required, simply look for the Perform 1 Year Guarantee icon on included products.
Final thoughts...
Start your woodworking journey with Perform. Whether you're looking for beginner-friendly tools, reliable workshop machines or affordable equipment for occasional DIY projects, Perform makes it simple to get started. Explore the range and start building with confidence.
Your first project starts here
Turning practice into purpose - simple woodworking projects to help you begin with confidence.
Explore beginner tools and projects
Discover more...
Leave a comment
