PROXXON 14 Piece Metric Socket Set (3/4")
- Takes heavy usage working on trucks, lorries and machinery
- 520mm long reversible ratchet with oil and acid resistant TPR grip
- Features a fine 72 tooth ratchet and a quick-release button for releasing sockets
- 500mm T-bar with slide
- 2 extensions: 200mm and 400mm
- 10 sockets: 22, 24, 27, 30, 32, 36, 38, 41, 46 & 50mm
- Supplied in sturdy steel box (powder-coated) with carry handle
- Weight 12.5 kg
A 14 piece socket set from the PROXXON range of industrial tools. It will take heavy usage dealing with larger fasteners as found on trucks, lorries and machinery. The 14 piece set includes a 520mm long reversible ratchet with an oil and acid resistant TPR grip. It features a fine 72 tooth ratchet and a quick-release button for releasing sockets. In addition there is a 500mm T-bar with slide and two extensions 200mm and 400mm. The 10 sockets that make up the set are 22, 24, 27, 30, 32, 36, 38, 41, 46 and 50mm. It comes in a sturdy steel box (powder-coated) with carry handle. Weight 12.5 kg.
Drive | 3/4" Square Drive |
EAN Barcode | 4006274233003 |
This product is classified as a Make to Order product.
Delivery time is approximately 3 weeks.
- Standard Delivery* - Free
