Veritas Scrub Plane with PM-V11 Blade
- The tool of choice for major stock removal
- Used by timber framers to replicate gouge marks
- PM-V11 blade for longest lasting, sharp edge
The scrub plane is the tool of choice for major stock removal, the first step when flattening rough stock by hand. Much like a low-angle smooth plane, a scrub is not usually used parallel to the grain, but at an angle of 30° or more.
Fitted with a PM-V11 blade, it offers a long lasting, sharp edge. The blade edge is ground with a 75mm(3") radius, so that it takes an aggressive cut. This is the tool you use to get stock into a condition where you can then use a smooth plane. The curved cutting edge of the 38mm(1.1/2") wide by 4.7mm(3/16") thick blade gives a distinctive, hand-worked texture to the workpiece. It is sometimes used by timber framers to replicate gouge marks.
This is a single-iron tool, meaning there is no cap iron or chip breaker. Set screws along the side prevent the blade from shifting sideways when knots are encountered. The ductile cast iron body is accurately machined and ground so that the sole is flat. A very refined yet rugged performer.
The Veritas scrub plane measures 273mm(10.3/4") long overall and weighs 1.4kg (3lb).
EAN Barcode | 5052511128778 |
Nett Weight | 1.4 kg (3lb) |
Plane Blade Width | 38 mm (1.1/2") |
Sole Length | 273 mm |
- Standard Delivery* - Free
